Transistor oscillation circuit for low power transmitter
Source: InternetPublisher:小胖友 Keywords: Transmitter transistor oscillation circuit low power Updated: 2021/01/15
Shown is a transistor oscillator circuit for a low-power transmitter . It is
composed of carrier oscillator VT1, modulation amplifier VT2 and power supply circuit. vri is a carrier oscillation transistor. Its base circuit is connected to an LC parallel resonant circuit. Fine-tuning CT can
change the frequency of the carrier signal. The oscillation signal is output from the emitter of VT1 and sent to the base of the modulation amplification transistor VT2 through the coupling capacitor. The modulation signal is also added
via a capacitor (4.7 yF), a resistor (4.7 kfl) and a coupling capacitor (100 pF) . The carrier signal and modulation signal are amplitude modulated (AM) in VT2, and then output by the collector, and the signal is emitted from the antenna.
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- An article explains the working principle of the Wheatstone bridge
- What are the parts of the fpga design process
- Datasheet/Pinout/Technical Specifications of LMC555
- Working principle/advantages/disadvantages/size of optical fiber
- DIY a decorative lamp
- Why use PWM? What are its advantages?
- Experimental circuit based on 4040 binary adder counter
- LED Night Light
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Small power switching power supply circuit diagram
- Highly stable sinusoidal oscillation circuit
- Variable frequency transistor oscillation circuit
- Small power UPS power circuit and production
- Small power power converter circuit
- Infrared transmitter 1 circuit diagram
- Small power uninterruptible power supply circuit diagram
- far field transmitter circuit
- Infrared transmitter circuit diagram
- LED transmitter linearity control circuit
