Thermocouple temperature measurement circuit
Source: InternetPublisher:张三叔 Keywords: Thermocouple temperature measurement circuit AD Updated: 2021/05/06
It is a thermocouple temperature measurement circuit using AD 594C . In addition to the amplifier circuit, the AD594C chip also has a temperature compensation circuit.
For the J-type thermocouple, it can obtain an output of 10m.U℃ after laser trimming. The accuracy is ±1℃ in the measurement range of 0~300℃. If AD 5.
Connect the 94C output to the A/D converter to form a digital display thermometer. 2820B in the circuit is a voltage/ current converter, which converts the voltage signal amplified by the operational amplifier Al and
corresponding to the temperature into a 4~ZOmA current loop for long-distance transmission.
- Electromagnetic radiation monitor
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- Level measurement circuit composed of AD737
- NE555 makes a simple and practical acupoint detector
- Digital strain gauge circuit using MAX1492/MAX1494
- Transistor reverse breakdown voltage tester-----Transistor tester
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- DC power meter
- Typical two-stage low-pass filter circuit
- Differential amplifier circuit
- AD power supply circuit design experience, worth collecting
- LED lighting display detection circuit with overload protection
- AD8202 two-stage system structure application circuit diagram
- AD594 to 597 basic application circuit b
- DK-5A, DK-5AD AC power supply control circuit
- AD2S80A, AD2S81A, AD2S82A RDC monolithic integrated circuits
- RTD sensor and 24-bit AD7711A circuit
- 8-bit AD circuit block diagram of ML2252
- AD22050 amplifier circuit
- Precision current source circuit diagram using AD586
