Electric blanket internal disconnection measurement circuit
Source: InternetPublisher:两手空空 Keywords: Electric blanket measuring circuit BSP LED Updated: 2020/02/02
Find the circuit for the internal disconnection of the electric blanket. The working principle is: M spot welding has a wire of about 2cm as the inductor. When the inductor
is close to the live mains live wire side, the induced voltage is rectified by VD and changes
from VT1 to VT3. The composite tube is amplified and added to the base of VT4
to turn on VT4. LED light display: When the induction body is far away from the live wire or the live
wire is not charged, because there is no induced voltage VT1-VT3 has no output, VT4 cannot
get the bias current and is cut off, and the LED goes out.
Component selection and fabrication are as follows.
The value of the triode g>20, Ieeo is as small as possible; the light-emitting diode I. ED
can choose any model; the value of resistor R is generally tens of ohms, and RP is a semi-variable resistor.
During debugging, the induction body (induction test pen) should be placed close to the live wire, and the resistance of RP should be changed to make the LED go from extinguished to illuminated. And when
leaving the line of fire, I. ED should go out. When
using a test pen to check the electric blanket , you should disconnect any of the two joints of the heating wire and the power cord, wrap the disconnected wire end with an
insulating wrapper, and then insert the side of the power cord plug connected to the resistance wire into the live The live wire trapping hole (to prevent electric shock, you can also string a small capacitor with sufficient voltage resistance
), so that the induction body of the electric test pen is close to the electric heating wire, and search sequentially from the end that is not disconnected. Once the LED goes out, you have found it. The break.
- Make a Simple Darkness Detector Circuit
- 4040 Mobile Phone Electromagnetic Radiation Demonstration Experiment Circuit
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Simple infrared detector
- Homemade LED digital display photovoltaic meter
- Making an Induction Electroscope Using CD4069
- Transistor reverse breakdown voltage tester-----Transistor tester
- direct coupled amplifier circuit
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- Geiger counter circuit diagram
- Motor overcurrent protection circuit
- Set timing circuit when power is on
- Excellent performance household inverter power supply circuit
- Inpatient pager circuit
- High-efficiency speaker circuit for rural stage
- Egg warming circuit
- Agricultural spraying and insecticide control circuit
- Poultry warming temperature control circuit
- Parallel crystal oscillator
- Sawtooth wave generator circuit (2)
