Infrared human body detection circuit
Source: InternetPublisher:柯南道尔 Keywords: Infrared human body detection circuit infrared sensor Updated: 2020/01/18
The infrared human body detector uses an infrared sensor , which can detect changes in infrared energy emitted by objects in a non-contact manner and
convert it into electrical signal output. Its packaging usually comes in two forms: metal packaging and plastic packaging. Pyroelectric infrared sensors are distinguished from the internal structure
and have two types: single element and dual element. The dual-element type receiving wavelength is 6.5-14ym. Suitable for human body sensing of boat theft system. The single-element receiving
wavelength is 1-20ym, which is suitable for temperature remote sensing, but can also be used in anti-theft and automatic control systems.
In order to improve the receiving sensitivity of the pyro infrared sensor, a Fresnel lens is usually added in front of the sensor, so that a large number of infrared light pulses
enter the pyro infrared sensor , thereby increasing the control distance, which can generally reach more than 10m. Shown in the picture is a dual-pulse infrared human detector
. This circuit uses a dual - element pyroelectric infrared sensor as the detector of the circuit. When the detector receives the human body signal, it outputs a
weak low-frequency signal with a frequency of about 0. 3 ~ 3 Hz. A 1-4 and A 1-3 form a two-stage low-pass filter amplifier. A1-1 and A1-2 form a window
comparator. A 2-1-A 2-4 constitute a single-limit comparator. U. A high level on the terminal indicates there is an output signal. The Uoi terminal can be used to detect slowly changing signals.
- Balcony intelligent invisible anti-theft net
- Electromagnetic radiation monitor
- Analysis of valid and fault conditions of differential signals
- 3 1/2, 4 1/2 digit intelligent digital voltmeter circuit composed of MAX1492/MAX1494
- Leakage Tester
- How to Use a Radio as a Metal Detector
- Homemade Metal Detector
- How to create a simple oscilloscope using the Basys3 board
- AC equivalent amplifier circuit
- DS8 type 100V, 5A mutual inductance three-phase three-wire electric meter wiring
- Paper thickness detection circuit
- Machine tool maintenance bearing fault detection circuit
- Overcurrent detection circuit
- Object presence and displacement detection circuit
- Woodworking hand planer safety device detection circuit
- Three-phase AC power supply phase sequence detection circuit
- Light sensor particle size distribution detection circuit
- Infrared two-dimensional temperature distribution detection circuit
- Contact combustion type CO detection circuit
- Carbon dioxide gas sensor detection circuit
