Multimeter DC current measurement circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: Multimeter current measurement DC current measuring circuit Updated: 2020/07/31
Set the left switch of the multimeter to position A and the right switch to any current range position. A DC
current measurement circuit can be formed as shown in the figure .
In the figure, the lkSl resistor and the adjustable resistor 1.4kfl are always connected in series with the meter
for temperature compensation. The rest of the resistors are connected as shunt resistors in a closed
circuit. When the range is 50yA, all the resistors are used as shunt resistors, including
the 121dl and 2.25kfl resistors. Inside. In other ranges, f connects
part of the shunt resistor in series to the meter branch, thereby reducing the actual shunt current.
Therefore, the current range can be changed by placing the switch in different range positions
- New function added to MF-47D multimeter - infrared remote control detection
- Temperature Range Monitoring System
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Using a Remote Control to Make a Crystal Oscillator Frequency Tester
- Simple and easy to make zero degree detector
- Four logic probe circuit diagrams
- How to create a simple oscilloscope using the Basys3 board
- AC ammeter circuit
- Digitally controlled operational amplifier gain circuit
- Typical two-stage low-pass filter circuit
- Capacitive sensing detection circuit
- Bus door status detection circuit
- LED lighting display detection circuit with overload protection
- Multimeter AC/DC automatic conversion circuit diagram
- Positive peak detection circuit
- α-ray application detection circuit
- αβγ particle detection circuit
- Underwater acoustic sensor detection circuit
- Current output light detection circuit
- Long wave infrared detection circuit
