Bus door status detection circuit
Source: InternetPublisher:已注销 Keywords: Status detection detection circuit Hall sensor Updated: 2020/04/01
![Bus door status detection circuit](http://www.eeworld.com.cn/circuit/upload/51d5af32b30cc32f44245f96fd7bc1a2/0e359677e5588a53f01844abd622b88f.jpg)
The picture above shows a bus door status detection circuit. This circuit is mainly composed of three Hall sensors and is suitable for indicating the door status in various cars. Three Hall sensors are installed on the door frame of the bus door, and magnets are installed at appropriate positions on the door. When the door is open, the magnet is farther away from the Hall sensor so that its output terminal outputs a high level . If any one of the three Hall sensors detects that the door is not closed or locked, the NOR gate outputs low level and the red indicator light turns on; if all three sensors output high level, the NAND gate outputs high level and green The indicator light is on, showing the current status of the door in real time.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- Analysis of the working principle of switching regulator
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- How to Make a Soft Latch Circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- An ultra-low output voltage regulator
- Integrated regulated power supply with continuously adjustable output voltage
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Adjustable voltage regulated power supply circuit
- A low-cost, high-reliability battery charger for electric vehicles
- Simple infrared detection circuit
- Using window discriminator as intensity detection circuit
- AC voltage regulating circuit working condition detection circuit
- α-ray application detection circuit
- and light detection circuit
- Light detection circuit
- Differential light detection circuit
- RMS sensor detection circuit
- Film thickness detection circuit using eddy current method
- Photoelectric pulse detection flying object injection speed detection circuit
