Structure of air conditioner horizontal air deflector drive motor and circuit
Source: InternetPublisher:黄土马家 Keywords: Motor air conditioner CPU Updated: 2020/10/11
Shown is the structure of the air conditioner horizontal air deflector drive motor and circuit. The motor is a stepper motor. The drive signal is output by
the CPU @~@ pin and is amplified by IC702 to drive the motor. The fault can be identified by detecting the output signal of the CPU and the output signal of IC702 respectively
. The signal output by IC702 has the opposite phase to the output signal of the CPU . If there is a signal to drive but the motor does not rotate, the motor is
faulty: if there is no signal, check the power supply again. If the power supply is normal, the drive circuit is faulty.
- Car ice warning circuit sharing
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- DIY an electromagnetic levitation device
- Introduction to the internal structure of the Delta winding motor
- Squirrel cage asynchronous motor reverse braking control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- Magnetic door and window anti-theft alarm
- Infrared detection alarm
- Precious home appliance anti-theft alarm
- Vibration anti-theft alarm circuit
- Is the power supply system easy to manage?
- Rural fish farming control circuit
- Mobile phone camera flash control circuit
- Stapler control circuit
- Car window control circuit
- Switching interface circuit in timing query mode
- External circuit structure of CPU clock signal generation circuit a
- Internal structure of RT9245 chip
- Voltage stabilizing circuit for CPU power supply circuit
- Typical circuit connecting MAX1204 to CPU
