Car window control circuit
Source: InternetPublisher:子丑寅卯 Keywords: control circuit MOSFET Updated: 2021/08/04
Two half-bridge intelligent power driver chips BTS 7960B are combined into a full-bridge driver
to drive the DC motor to rotate to raise or lower the window. BTS7960B is a high-current half-bridge integrated chip used in motor driving.
It has a P-channel high-side MOSFET , an N-channel low-side MOSFET and a driver 1C. P-channel high-side switching eliminates
the need for a charge pump, thereby reducing electromagnetic interference (EMI). The integrated driver IC has logic level input, current diagnosis, slope adjustment,
dead time generation and over-temperature, over-voltage, under-voltage, over-current and short-circuit protection functions.
The typical on-state resistance value of BTS7960B is 16mfl, and the driving current can reach 4.3A, so even in the cold winter,
the safe start of the car window can still be ensured. Adjusting the size of the external resistor connected to the SR pin can adjust the MOS tube turn-on and turn-off time, and has the function of preventing electromagnetic interference. The 1S pin
is the current sense output pin. The INH pin is the enable pin, and the IN pin is used to determine which MOSFET is turned on. When lN-1 and INH-
l. The high-side MOSFET is turned on and outputs high
level. When IN=O and INH-1, the low-side
MOSFET is turned on and outputs low level. It is controlled by the 16-bit
microcontroller XC164CS. The switching action of BTS7960B
is used to regularly
monitor the system status. Receive appropriate fault feedback signals and exchange
fault information and button control information with the central body controller
through the vehicle network (CAN bus) , thereby
displaying fault
content
on the user interface in a timely manner and performing real-time monitoring of the power windows. Control I is to avoid
current spikes when the window motor starts.
The soft start function is realized by controlling the pulse width modulation (PWM) signal
with a frequency of 20kHz on the lower arm switch tube.
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- DIY a practical audio-visual doorbell
- Grain temperature measuring instrument circuit
- Differential voltage or differential current alarm
- Water dispenser double sheet control circuit
- Electric massager circuit
- Smoke alarm circuit (1)
- SCR control buzzer circuit
- One use and one standby constant pressure water supply frequency conversion speed control circuit b
- Simple temperature control circuit diagram
- Differential amplifier emitter negative feedback gain control circuit
- Micro remote control receiving and control circuit
- Boiler control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- 24h automatic switching capacitor control circuit
- Haier KFR-25GW air conditioner control circuit schematic diagram
- Bedside touch light detection control circuit
- Photoelectric detection output control circuit
- Forward and reverse control circuit of micro DC motor b
- AGC loop of MOSFET
