Circular light control circuit
Source: InternetPublisher:天天都吃好吃的 Keywords: Cycling light light control circuit BSP NAND gate Updated: 2021/03/25
Shown is a cyclic light control circuit. In the circuit, rCl is a two-input terminal four -NAND gate CD4011, in which
a multivibrator is composed of NAND gates 1 and 2, and an RS trigger circuit is composed of NAND gates 3 and 4 to process the pulses generated by the multivibrator. Shaping, and then outputs the clock pulse
from the output terminal of NAND gate
4 to the Cp terminal of IC2.
IC2 is a decimal counting/frequency divider CD4017. When its Cp terminal inputs a clock pulse, high-
level pulse signals will appear sequentially at the output terminals Qo-Q3. When Qo-Q3 appear high level in sequence, the solid-state relays Kl~K4 are triggered and turned on in sequence, so that the corresponding lamps H1~
H4 are lit one by one. After clearing IC2, the above process starts again, thus realizing the function of controlling the light cycle.
in the circuit. The sequential lighting time of each street lamp and the time for all lights to be turned off are the same. Adjusting RP1 can make the time
change between 0.1-10 s.
- Peripheral circuit of automotive motor controller power supply chip
- DC motor drive circuit composed of L293D
- Motor automatic cycle control circuit
- Motor self-starting circuit
- Motor control circuit for starting and running without phase loss
- Simple phase failure protection circuit composed of intermediate relay
- Design and manufacture of three-phase motor protection circuit
- Audio interface protection circuit
- An experimental model of an infrared radio alarm
- Password type motorcycle anti-theft device
- Electric massager circuit
- Rural vegetable greenhouse lighting circuit
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit a
- Domestic KD8041 integrated phase locked loop
- base amplitude modulation circuit
- Differential Amplifier Circuit
- Motorcycle flash light circuit
- Sawtooth wave generator circuit (1)
