Audio PWM processing circuit
Source: InternetPublisher:无人共我 Keywords: PWM audio processing circuit field effect transistor Updated: 2021/06/07
Shown is the circuit block diagram of the PWM processing circuit and digital power amplification. Since the signal output by the A/D converter cannot be
directly interfaced with the digital power amplification, the PWM processing circuit first converts the serial digital audio signal into a pulse width modulated signal. (
PWM for short ). This is a new digital processing method developed to facilitate power amplification, which turns a multi-channel digital signal with a complex structure
into a simple pulse signal. Digital power amplification is actually a pulse power amplifier. The output stage in the integrated circuit
uses dual field effect tubes . During the high level of the pulse, the upper field effect tube is turned on and the lower field effect tube is turned off. During
the low level , the upper field effect tube is turned off. The field effect tube below is turned on. The output pulse width modulated signal can be converted
into an analog signal and sent directly to the speaker through the RC low-pass filter. Power amplification is virtually distortion-free.
- Low noise hybrid headphone amplifier
- Audio vibration thawing circuit
- Circuit diagram of Rongsheng CFXB1, 3 and 4 double lamp thermal insulation automatic rice cooker
- LG Industrial iV5 inverter typical application circuit (2)
- High frequency signal input switch circuit a
- Printed circuit diagram of power converter
- Hot and cold water dispenser circuit household appliance circuit
- Amplifier DIR1703+PCM1738 DAC PCB circuit diagram
- Water and electricity saving faucet circuit 2
- Transformer AC contactor DC operation circuit b
- C-MOS inverter and its internal structure
- A cascade amplifier consisting of a grounded source and common base amplifier
- LCD backlight power supply circuit
- Internal functional block diagram of SC1486 power management chip
- Voltage stabilizing circuit with soft start function
- Basic amplifier circuit of field effect transistor (a)
- Power amplifier using field effect transistor as output
- Typical application circuit of XLT604 in AC and DC input
- Three-terminal PWM switching power supply-PWR-TOP200 series and applications 03
- Simple PWM DC motor speed regulation circuit
