Power amplifier using field effect transistor as output
Source: InternetPublisher:明天见 Keywords: FET power amplifier BSP signal-to-noise ratio Updated: 2021/06/14
The circuit principle is shown in Figure 2-2. It consists of an input stage, a voltage push stage and a power output stage. Except for the input and output stages
, direct coupling is used between all stages.
VTi and its peripheral components form the input stage, and its output is directly coupled to the base of the driving stage VT3. VT2 is
the constant current source load of VT3.
VT4 and VTs are composed of field effect power tubes to form a complementary push-pull power amplifier output stage o
Rs; Min and island form a feedback system, which determines the gain of the whole circuit: Av = R8/R6 about 26dBo.
Adjust Rio so that the quiescent current of VT4 is lOOmA.
Technical indicators:
Output power: Po= 32W (8fl);
Frequency response: 20Hz~ 22kH (-3dB);
Signal-to-noise ratio : >90dB;
Total harmonic distortion: <o-05%0
- Biliary duct 2A3C Class A amplifier
- Design and production of class AB headphone amplifier
- LM4766 Dual 40W+40W Power Amplifier
- Installation of electron tube differential amplifier circuit
- Make cheap speakers using waste circuit boards (TDA1013)
- Class AB2 Amplifier-McIntosh MC80
- Dual power supply audio power amplifier circuit composed of LM3875
- LM4902 differential input audio amplifier circuit
- LM4903/4905 differential input audio amplifier circuit
- Active power amplifier circuit composed of TDA2003
- Motor overcurrent protection circuit
- Bone hyperplasia treatment circuit
- Homemade disinfectant circuit
- soil content measurement circuit
- Egg heating control circuit
- AC voltmeter
- Frequency modulator composed of NE566
- Simple AGC circuit in transistor radio
- color discrimination circuit
- Digital stopwatch display circuit
