Indoor unit remote control receiving and display circuit
Source: InternetPublisher:清宁时光 Keywords: Remote control reception display circuit BSP microprocessor Updated: 2020/12/26
Shown is the remote control receiving and display circuit of the Xinke KI;R-28GW/BP inverter air conditioner indoor unit . IC201 is a remote control receiving
circuit. It receives the infrared light signal sent by the remote control transmitter, and outputs the control signal through photoelectric conversion, amplification, filtering and shaping in IC201.
The signal is sent to the Iyj@ pin of the microprocessor IC104. The microprocessor uses this signal as the basis for indoor control. , the circuit of the outdoor unit is controlled. The @, ②, ⑦, and ⑥ pins of
the microprocessor (CPU) output LED display drive signals to display the working status of the air conditioner.
- Types/advantages and disadvantages of repeaters, how do repeaters work?
- TA8164P FM Radio
- Design and production of satellite receiver crash recovery circuit
- QMR1/QMR2 AM/FM 868/433.92 MHz Receiver Module
- Common RF receiving circuit design for toys (3 high-frequency parts)
- TXl00 ASK 1 GHz~100 MHz transmitter module
- CYWUSB6932 GFSK 2.4 GHz Wireless USB Interface Transmitter
- MAX2900/2901/2902 BPSK/ASK/OOK 915/868 MHz Transmitters
- MAX2440/MAX2441/MAX2442 900 MHz Receivers
- rfHCS362G/362F ASK/FSK 440~310 MHz KEELOQ Code Hopping Transmitter
- Motor forward and reverse control wiring diagram (2)
- Peanut and melon seeds roasting machine circuit
- Frequency modulator composed of NE566
- Simple AGC circuit in transistor radio
- collector amplitude modulation circuit
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
- Differential Amplifier Circuit
- Three primary color display circuit
- Sawtooth wave generator circuit (1)
