V-segment RF modulator
Source: InternetPublisher:李商隐身 Keywords: RF modulator BSP integrated circuit Updated: 2021/07/05
The V-band RF modulator is a modulator with an output frequency in the VHF band range, as shown in Figure 5-1.
The frequency of the V-segment radio frequency oscillator is lower than that of the U-segment oscillator, so it can be made into an oscillation circuit unit, all made in
an integrated circuit . TA7673P is an integrated circuit that completes radio frequency modulation . The video signal is input from the @ pin to In ICI, video clamping
and white peak limiting are first performed to clamp the sync head at a certain level and obtain a stable amplitude, which is then modulated on the radio frequency carrier. ◎Pin and ⑩Pin
are connected to the 4-channel and 3-channel surface acoustic wave resonators respectively. The same circuit in Icl forms radio frequency oscillation. The ⑦ pin oscillates at a high level and the 4-channel image
radio frequency signal is output from the @ pin.
- How to Build a Simple FM Radio Receiver on a Breadboard
- How to use FPGA and RS485 for industrial communication
- FMA9901A FM broadcast dedicated antenna
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- S9018 single tube super regenerative FM receiving circuit
- FM transmitter in a matchbox
- DKl000R OOK 315 MHz Receiver Module
- MICRFl03 ASK 1 GHz~800 MHz Transmitter
- nRF401/nRF403433/315 MHz Transceiver
- MICRF500 FSK 1000~700 MHz Transceiver
- Smoking Cessation Circuit
- Egg warming circuit
- Chicken supplementary light to increase egg production rate circuit
- Straw returning to field crusher circuit
- base amplitude modulation circuit
- Schiller oscillator circuit
- Second-order active band-stop filter circuit
- color discrimination circuit
- Three primary color display circuit
- Small current generator circuit
