Timer circuit for blasting
Source: InternetPublisher:常思一二 Keywords: Timer circuit switch APP Updated: 2021/09/11
NE7555 and peripheral components form a clock oscillation circuit. The oscillation frequency period of NE7555 is adjusted by potentiometer BP. Its minimum time is 1 min and the maximum setting time is 10h. Each time the switch SB is pressed, the circuit will work for one cycle , then K pulls in, the normally open contact K1 closes, replacing the SB switch to turn on the power supply, and after a timer of 10 hours, K automatically releases the power outage. The timer circuit for blasting is as follows.
![Timer circuit for blasting](http://www.eeworld.com.cn/circuit/upload/6120b57dc6909b5cfee28b2247b42ab7/4c72fa5bf2e6e9fd23231900ef4995e4.jpg)
- In-depth analysis of DC-AC converter inverter
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Step-down power supply for driving relays
- Driving circuit that controls LED brightness using PWM signal
- LED rechargeable flashlight circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Homemade low-power UPS
- CNC regulated power supply production
- Constant current charger using light emitting diode as voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- Simple clock controlled timer circuit
- Timer circuit using Darlington circuit
- Highly reliable universal timer circuit
- Intermittent working long timer circuit
- "HAPPY NEW YEAR" billboard circuit diagram
- Programmable timer circuit diagram
- Precision timer circuit diagram
- Multi-stop timer circuit diagram
- Circuit diagram of a timer that is set as soon as the power is turned on
- 3-speed timer circuit diagram
