Electrician night work flash indicator circuit
Source: InternetPublisher:zht24 Keywords: Indicator light BSP Updated: 2020/10/20
The circuit of flashing warning light for night operation is shown in the figure.
cl, VD, island and Zener diode VS1 form a capacitor step-down,
half-wave rectification, filtering and voltage stabilizing circuit. The 555 time base circuit and photosensitive
transistor VT form a light-controlled oscillator. The light intensity is high during the day , and the resistance
between the collector and emitter of VT is very small.
The internal discharge tube of 555 is discharged, so the circuit does not oscillate. Its output pin
③ is low level, the bidirectional thyristor VTH is turned off, and the warning light
EL does not light up. As night falls, the light intensity is weak. As the resistance of VT increases
, the voltage of pin ④ of 555 also increases, the 555 circuit oscillates, and
pin ③ of 555 outputs the oscillation frequency, triggering VTH to turn on, causing EL -
to shine brightly. Changing the resistance of RP can change
the flashing frequency of the light.
- IR2153 emergency fluorescent lamp circuit diagram
- IRS2530D electronic ballast circuit diagram
- Low cost LED automatic emergency light circuit
- Design and production of rain control and light control timing controller based on P87LPC764
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Solar battery and charging circuit
- battery charging circuit
- Infrared remote control device circuit
- Telephone theft automatic notification device circuit diagram
- Gas and smoke alarm circuits with intermittent alarms
- Bone hyperplasia treatment circuit
- Electric massager circuit
- Egg heating control circuit
- base amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Audio function generator composed of ICL8038
- Wien bridge oscillator circuit
- Capacitive feedback oscillator circuit
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
