fire alarm circuit
Source: InternetPublisher:同住地球村 Keywords: Fire alarm alarm circuit BSP generator Updated: 2020/09/13
(1) Working principle of the circuit The circuit of the fire alarm is as shown in the figure. In the figure, the two parallel metal plates A and B are the two electrodes for detecting the flame
. When there is no flame, the two electrodes
are insulated. At this time, the gate of the field effect transistor
VT1 is connected to the ground through the 20MC1 resistor,
and the voltage generated by the drain current on the source resistor Rz is added to the gate
as the gate bias
(negative gate voltage) of the field effect transistor. At this time,
VTI works. In the negative gate voltage state, the drain
current is very small. Therefore, the voltage regulator tube VS does not conduct
, VT2 is cut off, the relay coil K does not
pull in, and the siren sound generator composed of VT3 ~ VT5
is powered off. There is no alarm sound.
When there is a flame, the gas between the two electrodes is ionized at high temperature, and electricity is conducted between the plates. The drain current of field effect transistor VT1 increases
, the voltage drop on R2 increases, the voltage regulator tube breaks down and conducts, VT2 also conducts, and the relay coil K is attracted. Its normally open contact K is closed,
the sound generator is turned on, and an alarm sounds.
VT3-VT5 form a substitute flute generator, which can produce an urgent substitute flute-like sound, giving people a feeling of tension. VT3 forms a triangle wave
generator , and its output triangle wave is added to the input end of the audio oscillator composed of VT4, vfs, etc., so that the output audio slowly rises
and falls like a siren, which is equivalent to the audio oscillator being modulated by the triangle wave.
- Circuit diagram of game score display using 7-segment LED
- IRS2530D electronic ballast circuit diagram
- Low cost LED automatic emergency light circuit
- Laser detection and indicating device system circuit design
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Mains undervoltage and overvoltage protection circuit 2
- One of the circuits that control one light in multiple placesb
- Two-way electronic music doorbell circuit
- Incandescent lamp dimming circuit using thyristor part 4a
- Night target display circuit diagram
- Bone hyperplasia treatment circuit
- Pulse therapy circuit
- AC voltmeter
- Domestic KD8041 integrated phase locked loop
- collector amplitude modulation circuit
- Series crystal oscillator
- Schiller oscillator circuit
- Guest arrival signal recognition circuit
- Power phase sequence display circuit
- Sawtooth wave generator circuit (2)
