Home appliance anti-theft alarm circuit
Source: InternetPublisher:smallembedded Keywords: anti-theft alarm alarm circuit trigger Updated: 2021/08/11
(1) Circuit working principle The circuit principle is shown in the figure.
VTH, Ri and SB form a thyristor trigger switch circuit; JC1, Brother,
VT1, VT2 and BL form an analog siren circuit. Normally, SB is
pressed by household appliances, causing its two normally closed contacts to disconnect, VTH is blocked without a
trigger signal , and the alarm does not work. When household appliances are moved
. The two contacts of SB are automatically closed, and the trigger end of VTH passes through R. The trigger signal is obtained from the
positive electrode of the power supply , rrH is turned on, and IC1 is energized to work.
The siren acoustic signal output is amplified by VT1 and VT2,
driving the speaker to emit a loud alarm sound. At this time, even if the appliance is opened
back to its original position or the SB is destroyed, the alarm sound cannot be stopped. Only
when the owner turns on the switch S installed together with the alarm and is difficult for others to find
, can the alarm be released.
- Example of LED AC drive circuit
- Circuit diagram of game score display using 7-segment LED
- Delayed gradual lighting with protection function
- Design and production of a practical electronic counting device
- Use NE555 to make a lighting and sound changing circuit
- Driving circuit for driving light-emitting diodes by IR53HD420
- Lighting audio control circuit
- Shock resistant soft start constant current LED lighting circuit
- SH-803R holiday lights ASIC
- Bedside lamp controller circuit
- Infrared anti-theft alarm circuit
- High sensitivity acoustic vibration alarm circuit
- Touch alarm circuit (1)
- Disconnected anti-theft alarm circuit (1)
- Smoke alarm circuit (4)
- Smoke alarm circuit (2)
- Gas alarm circuit (2)
- Mutual aid housekeeping alarm circuit
- Cable anti-theft cutting alarm circuit
- Rain alarm circuit diagram B
