Three and a half digital display counter circuit
Source: InternetPublisher:super_star Keywords: Counter circuit BSP pulse Updated: 2021/03/23
Shown is a three and a half digital display counter circuit . The counting display circuit in the circuit consists of CD4553, CD4511 and three common
cathode LED digital tubes. CD4553 is used for counting, and CD4511 is used for decoding. The highest count value of this circuit is "J999".
When the circuit is powered on, due to the action of the cl and Rt reset circuits, the output terminal of the NOR gate 2 is at a low level. LED1 and LED2 do not emit light, and
the thousand-bit "I" composed of them does not light up. When the circuit count changes from "999" to "000", the @ pin of CD4553 outputs a positive pulse . This
pulse causes the NOR gate 1 to output a low level, and the output end of the NOR gate 2 becomes a high level to turn LED1 and LED2 lights up to display the count, shovel 1000",
thus forming a three-and-a-half-digit counting circuit.
- Which one is better, NPN or PNP transistor?
- An article explains the working principle of the Wheatstone bridge
- How does sand become chips?
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Share a Motorola amplifier circuit
- What is a Demultiplexer
- What is the difference between high-side and low-side resistive current sensing
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- FL52C4 induction electronic greeter
- Motor forward and reverse control wiring diagram (2)
- Analysis of rectifier circuit types and principles
- Biogas concentration detection line
- Farmland drainage automatic control circuit
- AC voltmeter
- base amplitude modulation circuit
- Amplitude modulation circuit composed of MC1496
- Differential Amplifier Circuit
- Fault signal trip circuit
- Sine wave signal generator circuit
