Photoelectric control bird song circuit
Source: InternetPublisher:闪电杰克 Keywords: Photoelectric trigger Updated: 2020/01/10
This circuit consists of a monostable timing circuit composed of lcl (NE555), and uses
a 3DU5 photosensitive transistor to receive light. When a light
beam passes through the light-transmitting window of 3DU5, 3DU5
is turned on, triggering the ② pin of IC1 to become low level.
Therefore, pin ③ is a high-level output, enabling IC2 to be powered.
Since the trigger terminal is directly connected to the negative pole of the power supply,
11C2 is triggered by the negative pulse and works, so
a burst of birdsong is emitted from speaker B. At the same
time, LED1 and LED2 also light up, like two small eyes shining. This state lasts approximately 45 seconds depending on the selection of components in the figure. If you want to
hear the birdsong longer, just increase the island or G. 1C2 is a KD-156 soft-packed music integrated circuit chip. There are two sounds in the memory,
one is the "ding dong" ringtone, and the other is the bird's cry. As long as the trigger terminal is connected to the negative trigger type, it will be the bird's cry. Pay attention when making.
- Build a Bluetooth-controlled wireless scoreboard
- A white light LED power outage emergency light
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- Infrared detection alarm
- Low illumination amplifier circuit
- Resistor value selection circuit
- 4-digit incandescent lamp display circuit
- Lighting audio control circuit
- Mains undervoltage and overvoltage alarm circuit 2
- Night target display circuit diagram
- How does an optocoupler amplifier circuit work?
- Photoelectric remote control power switch circuit diagram
- Photoelectric control weather forecast circuit
- Photoelectric control temperature circuit
- Photoelectric control attenuation circuit a
- Photoelectric pulse generating circuit
- Multifunctional photoelectric controller circuit
- Photoelectric target toy circuit
- Ultrasonic remote control lighting circuit
- Telephone flashing light circuit monitor circuit diagram
