Electric sewing machine power saving circuit
Source: InternetPublisher:zht24 Keywords: Save electricity Updated: 2020/02/29
The electric sewing machine power-saving circuit is as shown in the figure. The main components in the circuit are composed of Hall switch integrated circuit IC and relay K. Close
the switch os, turn on the power, and after R, Ci resistor-capacitor voltage reduction, silicon bridge UR rectification, G filtering, vs voltage stabilization, 12V DC
power supply is provided to the IC. When the operator does not step on the sewing machine, the magnet In the corresponding working position of the IC. K is powered on and closed, the normally closed contact is opened, and the sewing
machine is not powered on. The red light emitting diode LED lights up. On the contrary, when the sewing machine is operated, FI1
moves downwards under the magnet l fixedly installed on the clutch lever of the sewing machine . IC loses the magnetic field effect, its ③ pin is at high potential, K loses power and is released, the normally closed contact of the main circuit is reset, M runs, and the LED
goes out.
- S-Video/PAL Video Converter
- Using CD4017 to form an analog pendulum circuit
- Integrated AM and FM radio circuits for household appliances
- Galanz WP700 mechanical microwave oven circuit diagram
- Hemisphere brand BC-175 refrigerator circuit
- Senlan BT40 multi-unit proportional linkage
- Minsk brand MNHCK-22 refrigerator circuit
- Electronic disinfection cabinet circuit
- Fujiba W-8511 computerized microwave oven circuit diagram
- Transformer AC contactor DC operation circuit b
- Capacitor step-down power-saving circuit c
- Machine tool no-load self-stop power-saving circuit
- Household electric blanket power saving circuit
- Relay power saving circuit one b
- Intermittent cycle control start and stop circuit 7a
- Use NE555 to make push-button delay energy-saving lamps (3)
- Sound and light dual control delay energy-saving lamp (2)
- CA6140 lathe power-saving control circuit_2
- Electric blanket power saver circuit (2)
- Small two-cell battery booster MAX856 circuit diagram
