Relay power saving circuit one b
Source: InternetPublisher:两手空空 Keywords: relay power saving BSP Updated: 2020/07/16
When the relay pulls in, a larger starting current is needed so that the relay can pull in reliably. After pulling in, only a smaller
current can maintain its pull-in state to achieve the purpose of power saving.
Relay power-saving circuits are also suitable for contactors, electromagnets, and solenoid valves in principle.
(1) One of the relay power-saving circuits.
The circuit is as shown in the figure. The input signal of the circuit in Figure (a) is DC. Adjust the capacitor C to make the relay
KA reliably pull in, and adjust the current limiting resistor R so that the KA keeps the current at a minimum but can reliably pull in the relay.
The input signal of the circuit in Figure (b) is a pulse signal.
- Satellite TV room-to-room reception
- Share a home telephone recorder circuit diagram
- Lebao CFXB15-6 to CFXB40-6, CFXB40-2HD thermal insulation electronic multi-purpose rice cooker circuit diagram
- Senlan BT40 multi-unit proportional linkage
- Electric heating water dispenser circuit
- Simple stepless speed fan circuit
- Universal inverter deceleration braking circuit
- Color TV adds AV output socket
- Yangzi brand BCD-212, BCD-230 refrigerator circuit
- Touch fan speed regulator circuit
- Electronic thermometer circuit
- High-efficiency speaker circuit for rural stage
- Chicken supplementary light to increase egg production rate circuit
- Rural vegetable greenhouse lighting circuit
- Proportional frequency discriminator circuit
- Varactor Diode Frequency Modulator
- Series crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Sawtooth wave generator circuit (2)
