Pulser circuit to interrupt the light beam
Source: InternetPublisher:风向双子座 Keywords: Pulse Generator Updated: 2024/09/26
As shown in the figure below, the circuit outputs a pulse when an object on the conveyor belt blocks the light. The light source keeps the phototransistor on. This will produce a high logic level voltage on the Schmitt inverter and a low logic level compatible with TIL at pin 5 of the monostable circuit. When the object blocks the light, TIL81 turns off the Schmitt inverter to trigger the monostable circuit.
- Multifunctional LC Oscillation Circuit Demonstrator
- LM324 op amp makes a step wave generator
- Transistor Ringing Generator
- DC negative high voltage generator
- A/D converter with direct drive capacitive input composed of INA331/INA332
- AD585 12bit A/D conversion system circuit
- Oscillator circuit composed of 555 integrated circuit
- Five frequency standard frequency standard generator
- Variable start/stop ramp oscillator
- Voltage controlled audio oscillator with 0.2% accuracy
- Quantitative pulse generator circuit
- Adjustable pulse generator circuit
- Tachometer, single pulse generator, power loss detector, peak detector circuit diagram
- LED pulse generator
- Delay pulse generator circuit diagram
- Pulse generator circuit diagram
- 60HZ clock pulse generator circuit diagram
- Single junction transistor controllable pulse generator
- Low frequency pulse generator circuit diagram
- narrow pulse generator
