Quantitative pulse generator circuit
Source: InternetPublisher:黄土马家 Keywords: Pulse generator generator circuit counter BSP Updated: 2020/01/02
Shown is a quantitative pulse generator circuit that can set the number of pulses generated. The maximum number of pulses can be set to 999 and
can be used as a signal source for a stepper motor. The circuit consists of a three-level subtraction counter , a gated oscillator and an RS flip-flop. The subtractor is selected
to preset the binary 1/N counter C182. The gated oscillator is composed of NAND gates 1 and 2, and NAND gates 3 and 4 are buffer output stages. The RS
trigger is C039.
Since the all "0" output terminal of the ones counter lCl is connected to the PE terminal of the three-stage subtraction counter, once reset, the counter will
accept the preset number. The preset number terminal of the counter is connected to the BCD code disk switch, which can be controlled by the BCD code. Disk switch setting. At the same time, the RS flip-flop
is also reset, so that the gated oscillator cannot work and the circuit outputs a low level.
When a start signal is added to the input terminal of the RS flip-flop, the RS flip-flop flips and the gated oscillator starts to work. The output pulse of the oscillator
is also a clock signal added to the CL terminal of IC1, causing the counter to start counting down from the preset number. When the count is reduced to 0,
a high level appears on all "o" terminals of ICI, which resets the RS trigger. , the oscillator stops oscillating and the output no longer sends pulses. In this way, each time the circuit is started
, a preset number of pulses will be emitted.
- The unidirectional conduction current of the diode, the diode and its common uses
- Signal diode arrays/configurations, freewheeling diode operation
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- FPGA Features and Architecture
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- RC filter explained in detail
- Datasheet/Pinout/Technical Specifications of LMC555
- What types of force sensors are there?
- LED Night Light
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- electromagnetic field sensor
- Electric massager circuit
- Smoking Cessation Circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland irrigation automatic control circuit b
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Schiller oscillator circuit
- Crabo oscillator circuit
- color discrimination circuit
- Home appliance repair signal generator circuit
