High-power switching power supply composed of L4970A
Source: InternetPublisher:已注销 Keywords: High power switching power supply BSP Updated: 2021/06/16
As shown in the figure is a high-power switching power supply composed of L4970A . L4970A is a high-power monolithic switch integrated voltage regulator. The chip is packaged in SIP-15. Its characteristics are: (1) The input voltage must be >11V, usually between 15 and 40V; (2) Output voltage: fixed The output is 5.1V, which can also be set to an adjustable output through an external circuit , ranging from 5.1 to 40V; (3) The maximum output current is 10A; (4) The operating frequency is 200kHz; (5) Internal undervoltage detection and power-off reset are provided , power stage soft start and other special circuits .
![<strong>High power switching power supply</strong> composed of L4970A](http://www.eeworld.com.cn/circuit/upload/13919645e47d592826146686ed74bec3/1de63beb707beadc17b091eced4bf805.jpg)
- A very convenient small power supply circuit to share
- Practical and convenient fax machine power supply control circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Recommended circuits for different power on times of LM4911
- Single-power supply circuit for ISO122P/ISO124
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Transformerless AC-DC constant current LED driver circuit
- Car power 1.5V-12V six-speed converter
- Adjustable voltage regulated power supply circuit
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Electronic anti-asthma circuit
- Fish pond oxygenation reminder circuit
- Straw returning to field crusher circuit
- Greenhouse temperature control circuit
- Capacitive feedback oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- superheterodyne radio circuit
- Three primary color display circuit
- Power phase sequence display circuit
- Home appliance repair signal generator circuit
