Zero-crossing trigger circuit diagram based on thyristor
Source: InternetPublisher:拳制龙 Keywords: SCR circuit diagram trigger circuit AC voltage Updated: 2021/01/31
The zero-crossing synchronization pulse is a pulse at the zero-crossing moment of the 50Hz AC voltage , which enables the thyristor to trigger conduction when the AC voltage sine wave crosses zero. The zero-crossing synchronization pulse is generated by the zero- crossing trigger circuit . A more detailed circuit diagram is shown in the figure. In this figure, the voltage comparator LM311 is used to convert the 50Hz sinusoidal AC voltage into a square wave. The positive edge and negative edge of the square wave are used as the input trigger signals of the two monostable triggers respectively. After the two narrow pulses output by the monostable trigger are mixed by the diode or gate, the process corresponding to the AC 220V mains power can be obtained. Zero sync pulse. On the one hand, this pulse is added to the temperature control circuit as a trigger synchronization pulse for the thyristor , and on the other hand, it is also added to the T0 and T1 terminals of the 8031 as a counting pulse.
![Zero-crossing trigger circuit diagram based on thyristor](http://www.eeworld.com.cn/circuit/upload/955d09b1ca5b8df241207bfa2116b8be/2f7539b2949c9a632a592b47bb7bed92.gif)
- Schematic diagram of car cigarette lighter to USB power port
- Using Lead-acid Battery as Power Source for Walkman
- Practical and convenient fax machine power supply control circuit
- Driving circuit of switching power supply field effect tube
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- What kind of circuit is a voltage regulator circuit?
- LED rechargeable flashlight circuit diagram
- Current/voltage conversion circuit using current converter
- 3~15V 10A adjustable voltage regulated power supply
- Practical constant current charger-----Constant current charger
- Portable thyristor charger circuit diagram
- A new type of dimming SM9043 integrated circuit
- SH-809 Holiday Lights ASIC
- Disconnected anti-theft alarm circuit (2)
- SCR three-phase AC switch circuit diagram
- Driving circuit diagram composed of silicon controlled switching elements
- Maintenance of automobile thyristor voltage regulator
- Time base phase shift control silicon controlled voltage regulator circuit.gif
- Optocoupled thyristor circuit
- Triac makes light-emitting diodes flash
