High Speed FET Input Instrumentation Amplifier Circuit Diagram
Source: InternetPublisher:子丑寅卯 Keywords: FET instrumentation amplifier amplifier circuit diagram Updated: 2021/06/23
The circuit shown in the figure below is a high-speed FET- input, gain-5 instrumentation amplifier with a wide 35 MHz bandwidth and excellent AC common-mode rejection (CMR) performance of 55 dB at 10 MHz. This circuit is suitable for applications requiring high input impedance, fast instrumentation amplifiers, including RF, video, optical signal detection, and high-speed instrumentation. The high CMR and wide bandwidth characteristics also make it ideal for wideband differential line receivers.
Most discrete instrumentation amplifiers require expensive matched resistor networks to achieve high CMR performance; however, this circuit's use of an integrated differential amplifier along with on-chip matched resistors not only improves performance, reduces cost, but also minimizes printing Circuit board (PCB) layout area.
![High Speed FET Input Instrumentation Amplifier Circuit Diagram](http://www.eeworld.com.cn/circuit/upload/6d472cdb21adb6c90d390d688010de0e/782730a5dcaadd83712eb2315568e45f.jpg)
- Practical and convenient fax machine power supply control circuit
- Driving circuit of switching power supply field effect tube
- Recommended circuits for different power on times of LM4911
- How to use SBR to improve power conversion efficiency
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Dynamic power supply for power amplifier controlled by thyristor
- USB power socket using the car battery
- LM317T voltage regulation adjustable circuit diagram explanation
- Detailed explanation of mobile phone charger circuit diagram
- Homemade home inverter circuit diagram
- TDA7241 power amplifier circuit diagram
- TDA7233D power amplifier circuit diagram
- TDA2611A power amplifier circuit diagram
- TDA2008 power amplifier circuit diagram
- TDA2007 power amplifier circuit diagram
- TDA1516Q power amplifier circuit diagram
- TDA1514A power amplifier circuit diagram
- Sensor and AD822 type single power supply, power supply positive and negative limited output, low power consumption FET input operational amplifier circuit
- Oscillator circuit diagram using FETs and transistors
- Immune FET Measurement Circuit
