Do you know the technology of miniaturizing power transmission isolation into IC size packaging?
Source: InternetPublisher:抄写员 Keywords: Texas Instruments integrated transformer ic size Updated: 2021/04/28
What is EMI-optimized integrated transformer technology? Do you know it? Texas Instruments Incorporated (NASDAQ: TXN) today introduced the first integrated circuit (IC) developed using new proprietary integrated transformer technology: an industry-leading 500mW high-efficiency isolated DC/DC converter UCC12050 with lower electromagnetic interference (EMI). Its 2.65mm height helps designers reduce solution size (80% compared to discrete solutions and 60% compared to power modules) and is twice as efficient as competing devices. The UCC12050 is designed for improved industrial performance, with its 5kVrms reinforced isolation and 1.2kVrms operating voltage protecting systems from high voltage spikes (such as in industrial transportation, grid infrastructure and medical equipment).
TI's breakthrough integrated transformer technology enables high-density isolated DC/DC power conversion while maintaining low EMI. The single-package, surface-mount architecture provides designers with an easy-to-use, low-profile integrated circuit that reduces the bill of materials (BOM) and operates efficiently over a wide temperature range. EMI-optimized, low-capacitance transformers and quiet control solutions simplify EMI compliance while providing a reliable solution with a choice of enhanced or basic isolation. Download the white paper, "Power Through the Isolation Barrier: An Overview of Isolated DC/DC Power Supplies" to learn more about this new family of reinforced isolated DC/DC bias power supplies.
Key Features and Benefits of UCC12050
Small size and increased power density: The UCC12050 is available in a 16-pin small outline integrated circuit (SOIC) package measuring 10.3 mm × 10.3 mm × 2.65 mm, providing 60% efficiency, twice that of competing devices of the same size, and also Twice the power density of the relative isolated power module. Using 0.5W in the new architecture improves reliability, reduces the bill of materials, and simplifies board layout.
Lower EMI: The UCC12050’s integrated transformer with lower primary to secondary capacitance optimizes EMI performance, and its silent control scheme makes it easier for engineers to get their designs to pass the International Special Committee on Radio Interference (CISPR) 32 Class B electromagnetic interference Test as it leaves margin on both layers of PCB. This solution also eliminates external filter components typically required to meet EMI certification, such as low dropout regulators and ferrite beads, significantly reducing component selection and design time.
Reinforced Isolation, Wide Temperature Range: The UCC12050’s reinforced isolation with 8mm creep and clearance is used to protect and resist ground potential differences. Its high efficiency and wide operating temperature range (-40°C to 125°C) deliver more power under extreme conditions. Read the technical article, "Isolation 101: How to Find the Right Isolation Solution for Your Application," to learn how enhanced isolation, specifically the UCC12050, can help you save more time, effort, space, and even cost compared to other isolation options. bias power solutions).
This new high-density isolated power converter is the latest industry-leading device in TI's power management portfolio, providing small size and ease of use for any industrial application requiring isolation. Additionally, the new UCC12040 offers all the same benefits with 3kVrms basic isolation.
Packaging and availability
The UCC12050 and UCC12040 are available now in volume from Texas Instruments and its authorized distributors in a 16-pin 10.3mm x 10.3mm x 2.65-mm SOIC package. Engineers can use the UCC12050EVM-022 evaluation module to evaluate this product. The above is the analysis of EMI optimized integrated transformer technology, I hope it can help you.
- Using Lead-acid Battery as Power Source for Walkman
- Driving circuit of switching power supply field effect tube
- What kind of circuit is a voltage regulator circuit?
- Use pulse width modulation to get a precise output voltage
- Simple and practical LED lamp driving circuit
- LNK304 non-isolated LED light string driver circuit
- CNC regulated power supply production
- Constant current charger using light emitting diode as voltage regulator
- Homemade Electric Bike Fast Charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- 3v to 5v circuit diagram
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Transistor stabilized current power supply circuit 2
- CF1 (CF2) DC power supply circuit
- Super Class A power amplifier power circuit
- Industrial four-way programmable controller power circuit
- Neon light high voltage power supply circuit
- Common power circuits and applications 04
- CTX-C2 dual-band high-resolution color display power circuit
- COMPAQ 420G type SVGA color display power supply circuit
