Remote control transmitter circuit
Source: InternetPublisher:狂妄火龙果 Keywords: transmitter remote control BSP Updated: 2020/08/28
It is common for children and elderly people to be lost and searched everywhere, causing undue pain and economic losses to families; in addition, it also
gives opportunities for criminals and human traffickers to take advantage of them. To this end, design a radio remote control , wear a transmitter on the child or elderly person, and
wear a receiver on the guardian. When a child or elderly person is 3 to 4 meters away from their guardian (parent or nanny), the guardian will receive an alarm
sound. Since the distance is not far, they can be found quickly and are not easily lost. This device is especially suitable for crowded occasions such as holidays, shopping malls, and downtown areas.
The device consists of a transmitter and a receiver. Its circuit composition and principle analysis are as follows:
(1) Transmitter circuit The transmitter circuit
is shown in Figure 18-4. When VT3 is turned on,
forward bias is applied to VT1 and VT2, and
VTI and VT2 form a self-excited multivibrator to start
working, generating
a high-frequency constant-amplitude oscillation signal with a frequency of 1600 to 1800kHz. After
Li, Lz and cl resonant frequency selection loop, adjust
the size of cl, select the required transmission signal frequency
, and transmit it through the magnetic rod antenna.
Among them, L1 and Lz are wound with 80 and 40 turns of yarn-covered wire respectively, and the trimming capacitor c] is 5-30pF.
(2) Receiver The receiver circuit is shown in Figure 18-5. After the receiver antenna Li receives the signal from the transmitter, it
selects the remote control signal with the same frequency as the transmitter through the L2 and cj tuning loops . Since the received signal is very weak, it performs multi-level amplification through vri, VT2, and VT3 to promote the four-sound
When the integrated music piece works, due to the small output power, after amplification by the final stage VT4, the speaker Y works to emit music sound to remind the guardian to
find nearby children or elderly people.
- Transmitter Receiver Circuit for 80 Meter Amateur Radio
- How to use CAN protocol in Arduino
- Application of GaN power devices in array radar transceiver systems
- Design and production of satellite receiver crash recovery circuit
- FM microphone made by 9018
- RX3408 FM/FSK 500~20 MHz Receiver
- MICRF011 00K 440~300 MHz Receiver/Data Demodulator
- SB-200BRX superheterodyne receiving circuit
- RF2926 AM/FMASK/FSK/OOK 915/ 868/433 MHz Dual Conversion Transceiver
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- Analysis of rectifier circuit types and principles
- Homemade disinfectant circuit
- Peanut and melon seeds roasting machine circuit
- Farmland irrigation automatic control circuit a
- Diode Balanced Mixer Circuit
- Varactor Diode Frequency Modulator
- Diode square rate detection circuit
- Broadband high frequency power amplifier circuit
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
