RX3408 FM/FSK 500~20 MHz Receiver
Source: InternetPublisher:3228 Keywords: Receiver Updated: 2024/09/24
The RX3408 is a low-power receiver chip that combines a UHF phase-locked loop (PLL) with an intermediate frequency (FM) receiver. The receiving section of the RX3408 is suitable as an orthogonal FM demodulator and a second intermediate frequency downconverter for wireless FM double conversion. When the internal PLL of the RX3408 is combined with an external VC0, it can be used as a local oscillator generator for home radio receivers (FRs) such as mobile communications. The PLL section of the RX3408 also includes an 18-bit programmable input frequency divider, a reference oscillator output buffer, and a standby enable controller that is serially programmed.
The main technical features are as follows:
・There are audio filters and noise reduction circuits on the chip;
・Input frequency: PLL is 20 to 500 MHz, IF is 10 to 50 MHz;
・FM/FSK demodulation method;
・Data transmission rate is 2.4 Kb/s;
・Sensitivity: PLL is -15 dBm, IF is -90 dBm;
・The second intermediate frequency is 455 kHz;
・Audio output is 180 mV/ms;
・Operating voltage is 2.7~3.3 V;
・Current consumption: 4.0 mA with squelch off, 5.4 mA with squelch on.
RX3400 Typical Application Circuit (Operating at 434 MHz)
- LM386 makes an AM radio
- Change the frequency of the campus radio
- Frequency modulation circuit for crystal oscillator stabilization in radio transmitter alarm
- SB-200BRX superheterodyne receiving circuit
- Radio coding transmission circuit composed of MICRF102 and PT2262
- Rolling code radio transmitter circuit (HSC360/TDA5100)
- rfPICl2C509AG/509AF ASK/FSK 480~310 MHz with 8-bit microcontroller transmitter
- TX500 ASK 1 GHz~100 MHz Transmitter Module
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- RCV420 4~20mA Precision Current Loop Receiver
- Do you know about the miniature infrared receiver with sensitivity and noise suppression capabilities?
- Vishay infrared receiver, do you know it?
- Ultrasonic remote control receiver
- USB communication circuit
- Indoor unit communication circuit
- Two-way communication circuit circuit diagram
- Long distance serial communication circuit
- CAN bus communication circuit
- Wireless transmitter circuit diagram
- Time division multiplexing stereo decoder circuit
