DC power boost circuit b
Source: InternetPublisher:smallembedded Keywords: DC power supply boost circuit trigger Updated: 2021/10/15
The touch switch power supply circuit is shown in the figure. No external transistors are required on the small printed circuit board of the music block. The upper part of the figure is the "open" circuit.
When the "open" contact piece is touched, 1C1 is triggered . The positive half cycle of the music signal causes the switch tube VT1 to conduct, the relay KR pulls in, the contact krl
closes , and the positive power supply passes through Ri. VT1 provides bias current and the circuit is self-protecting. Contact kr2 is pressed at the same time to make the load work. The lower part is the "off" circuit.
When the "off" contact piece is touched, 1C2 is triggered , and VTZ is turned on when the sound bed signal is positive, causing the VT1 bias current to be bypassed and VT1 to be cut off. '
KR is released, the contact is disconnected, and the load stops working
- Build a simple buck-boost regulator and test it on a breadboard
- Basic circuit description of adjustable voltage regulator LM317
- Basic connection circuit of signal and power supply composed of ISOll3
- Single-power supply circuit for ISO122P/ISO124
- Transformerless AC-DC constant current LED driver circuit
- Detailed explanation of 5v charger circuit diagram
- Low cost and high performance LED constant current power supply
- Charging control circuit made by solar energy
- 3~15V 10A adjustable voltage regulated power supply
- MAX1811 Lithium Battery Charger Production
- Importance of Voltage Supervisors and Output Topology Selection
- Three-way DC-DC converter circuit
- Commonly used power circuits in printers
- Warm current power circuit a
- Boost circuit based on EL7516
- Photoresistor light-controlled boost circuit diagram
- Boost circuit diagram composed of ICL7660 and S80250
- Typical application circuit boost circuit diagram of LT1111
- Boost circuit diagram using LT1073
- Lithium battery boost circuit diagram
