Emergency braking circuit when accelerator is pressed accidentally
Source: InternetPublisher:同住地球村 Keywords: BSP switch Updated: 2021/06/27
When an unexpected situation occurs while the car is driving, the driver is nervous and mistakenly presses the accelerator as a brake, using too much force. This often closes the switch
at the lowest part of the accelerator , and then slams the accelerator to close the switch S. One situation. The circuit is shown in the figure.
NE555, Rj, cl, etc. form a trigger circuit . Normally, 555 is in the set state, pin ④ is high level, and K does not act. Its normally open contact
K is in the open state.
When the accelerator is pressed by mistake. K is closed, the ⑥ pin is at high potential, which resets the 555, K is closed, and its normally open contact K is closed. The solenoid valve DF is energized
, and the Gaoya gas supplies air to the braking mechanism through DF to brake the car and prevent accidents. occur.
- CD4017 simple doorbell
- DIY a practical audio-visual doorbell
- Video doorbell design based on Raspberry Pi
- Four water tower control schematic diagram
- morning bird
- Electric massager circuit
- Infrared blind cane circuit diagram
- GW-0520CH-PS switching power supply circuit diagram
- Box type electronic mousetrap circuit
- "Happy New Year" ring game console circuit
- Peanut and melon seeds roasting machine circuit
- Chicken supplementary light to increase egg production rate circuit
- Egg heating control circuit
- Farmland irrigation automatic control circuit b
- Mixer built with analog multipliers
- Audio function generator composed of ICL8038
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Motorcycle flash light circuit
- Digital stopwatch display circuit
- Sawtooth wave generator circuit (1)
