Low frequency oscillation circuit
Source: InternetPublisher:他们逼我做卧底 Keywords: Low frequency oscillation oscillation circuit BSP speaker Updated: 2021/10/22
Gate circuits
F4, F5, and F6 together form a low-frequency
oscillator to drive ultra-high-brightness light-emitting diodes
to flash. The light-emitting diodes can be arranged around
the booth to play a decorative role.
(4) How to use the product automatic introduction
machine must be pre-recorded before use. When recording,
press and hold K2i and the speaker will emit two beeps, and then you can record into the microphone. After recording the product introduction voice,
release S2. The speaker will beep again to indicate the end of the recording. If the recording time exceeds the time allowed by the chip, a
"beep, beep" will be emitted when the chip's allowed time is reached. "Two beeps will force the recording to end. S1 is the stop button. When the product introduction machine uses
voice introduction, just press Sl to stop the voice introduction.
- Hot wire spark plug control circuit
- UCC587x-Q1 power-on false alarm mechanism and initialization precautions
- Digital display time relay circuit
- Vehicle electronic fuel gauge circuit
- Electric massager circuit
- Infrared blind cane circuit diagram
- Thermocouple Temperature Transmitter
- EKG FM Demodulator Circuit
- Stapler control circuit
- Light controlled electronic bird circuit
- electromagnetic field sensor
- Rural vegetable greenhouse lighting circuit
- Particle clogging alarm circuit of wheat seeder
- Farmland drainage automatic control circuit
- DC ammeter
- AC voltmeter
- Junction field effect transistor mixer circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- High and low frequency signal generator circuit
