Peak voltage sample and hold circuit
Source: InternetPublisher:明天见 Keywords: Voltage sampling sample and hold circuit LF398 LM311 Updated: 2021/02/10
The peak voltage sample and hold circuit is shown in the figure. The peak voltage sampling and holding circuit consists of a sampling and holding chip LF398 and a voltage
comparator LM311 . The output voltage and input voltage of LF398 are compared through LM311. When V. > , LM311 outputs
high level and sends it to the logic control terminal ⑧ pin of LF398, making LF398 in the sampling state; when V. When it reaches its peak and then decreases. V,<V, the voltage
comparator LM311 outputs low level, and the logic control terminal of LF398 is set to low level, so that LF398 is in a holding state. Since LM311 uses
an open-collector output, a pull-up resistor is required. The pulse sent from the output end of the overvoltage detection circuit controls the conduction of the circuit switch.
When there is no overvoltage, the sampling capacitor is discharged. Otherwise, the sampling circuit keeps tracking the changes in the peak value.
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- Video doorbell design based on Raspberry Pi
- Digital display time relay circuit
- Telephone cipher circuit
- Grain temperature measuring instrument circuit
- One control three constant pressure water supply frequency conversion speed control circuit a
- Enhanced password lock circuit using AE1169
- 220V AC mains directly drives small relay circuit_3
- Wired centralized control circuit that directly starts the water pump motor
- Toy police car circuit
- Multifunctional high-precision sample and hold circuit diagram
- LM311 pin function and arrangement
- TTL logic level interface circuit composed of LM311
- Zero-crossing signal detection circuit
- AD conversion system using LF398 sample and hold device
- Step wave generator circuit diagram composed of sample and hold circuit diagram
- Basic application circuit for VF conversion using LM311
- Low drift sample and hold circuit diagram
- Sampling and holding circuit diagram using LF398H
- CA3080 sample and hold circuit diagram
