Accurately identify three primary color circuits
Source: InternetPublisher:newrudeman Keywords: BSP sensor Updated: 2020/02/24
It is a circuit that accurately identifies the three primary colors . The principle is based on the wavelength characteristics of the three primary colors (different wavelengths, peaks, and positions),
with the help of peak wavelength color filters and photodiodes, the spectral sensitivity covers the entire visible light area, and outputs x, Y, Z in Figure 7-23 , Zhijingqiuduo
is enlarged and A/D converted by U4A, U4B, and U4C to obtain the final results of (red-yellow), (green-blue) and (purple) colors. The most important issues in the actual use of
color sensors are the lighting power supply and light condensing system, and the area of the distinguishing element should be as small as possible in order to effectively form an illumination
point
on the object . It is most convenient to use incandescent lamps as the light source. As for the condenser system, attention must be paid to the focus of the condenser and
the diameter of the illumination point.
The color sensors currently on the market are relatively expensive and are used to identify lines and strips in robot production and competitions. ,k
In practice, infrared photoelectric reflective sensors can also meet the usage requirements.
- How to improve SiC traction inverter efficiency with real-time variable gate drive strength
- DIY a practical audio-visual doorbell
- Production of two-color music lantern
- Design of hydroponic farm based on IoT
- RF leak detector circuit diagram
- Music calendar using SMC6S37
- 220V AC mains directly drives small relay circuit_3
- Teana A33-EL anti-theft alarm system circuit diagram and schematic diagram 7
- Remote control fan speed regulator circuit
- Commonly used oil pump motor control circuits for presses
- Excellent performance household inverter power supply circuit
- stuttering correction circuit
- DC ammeter
- Domestic KD8041 integrated phase locked loop
- Integrated synchronous detector composed of analog multiplier MC1596
- Series crystal oscillator
- Voltage controlled power supply second-order high-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Color display circuit
- Power phase sequence display circuit
