Gyro amplifier circuit
Source: InternetPublisher:太白金星 Keywords: amplifier circuit robot sensor Updated: 2021/09/14
A gyroscope is a sensor that detects angular velocity . After obtaining the value of the angular velocity , the azimuth angle of the robot moving in the horizontal plane
can be obtained through integration
, which provides a basis for the robot's path navigation. With the help of
the vibration changes of the ceramic vibrator plating, the force exerted on the robot's attitude
rotation can be detected, thereby reflecting the yaw angular velocity. The gyroscope must be installed correctly
, because its installation has an impact on use. The output of the gyroscope must be
amplified and then sent to the A/D converter to read the angular velocity value. The amplification circuit
is as shown in the figure. Some companies also produce
integrated devices that combine gyroscopes and amplifiers.
- Method for converting a spark ignition system to an enhanced sequential spark ignition system for a 6-cylinder engine
- DIY a practical audio-visual doorbell
- How to use MFRC522 to create an RFID card reader security system
- Interpretation of CAN bus driving recorder system circuit
- What components and functions does the battery management system consist of?
- Disconnected anti-theft alarm circuit (1)
- One control three constant pressure water supply frequency conversion speed control circuit a
- Infrared blind cane circuit diagram
- Smart transmitter circuit diagram with hart interface
- Teana A33-EL anti-theft alarm system circuit diagram and schematic diagram 7
- Operation process of power sensor
- Remote Sensing Powered Sensing Amplifier
- Ultrasonic proximity sensor circuit
- AD7715 internal functional block diagram and pin function diagram
- 3 and 1/2 digit digital thermometer using triode as degree sensor
- Thermocouple Thermometer Circuit
- Electric guitar effect enhancement circuit
- Identification sensor amplification circuit diagram
- Sensor Two-Wire Current Transmitter
- Bridge sensor transmit/receive circuit (with isolated output)
