300W high fidelity power amplifier circuit
Source: InternetPublisher:闪电杰克 Keywords: Power amplifier circuit Updated: 2024/09/11
The output power of this amplifier circuit is 300W when the load is 8Ω and BTL mono, and 100W 100W when the load is 6Ω and stereo output. The circuit uses the high-power amplifier LM21CL of National Semiconductor. It uses an ordinary TO-3 metal package (the volume is the same as that of a general high-power triode), with a rated output power of 150W, a maximum supply voltage of 80V, and a maximum output current of 10A. The circuit is shown in the figure.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- TDA2009A power amplifier circuit
- FU-7 Tube Amplifier Homemade
- Auxiliary audio power amplifier circuit using LM4730/LM4731
- Dual power supply audio power amplifier circuit composed of LM3875
- A common-phase audio power amplifier circuit powered by a split power supply using LM1877
- LMl876 is used to assist the audio power amplifier circuit
- LM4915 is used for dual-channel amplifier circuit
- LM4820-6 audio power amplifier circuit
- Application of BTL power amplifier circuit composed of LM3886
- 90MHz transistor resonant power amplifier circuit
- Block diagram of multi-channel surround stereo power amplifier circuit using digital power amplification
- Auxiliary audio power amplifier circuit design based on LM4730
- Mono audio power amplifier circuit
- Integrated circuit OCL power amplifier circuit
- Discrete components OCL power amplifier circuit
- Composite complementary symmetrical OTL power amplifier circuit
- A757 power amplifier circuit
- BTL power amplifier circuit
- 22W power amplifier circuit
