Divider Circuit
Source: InternetPublisher:elleny Keywords: Divider circuit low pass filter Updated: 2024/09/09
As shown in the division circuit, A1 forms a voltage-controlled current source, A2 is a voltage comparator, and A3 forms an active low-pass filter. When the time constant R1C1 is equal to the clock pulse period T, the relationship between the circuit's output and input is:
Vo=-V2E/V1
If E=1V, then
Vo=-V2/V1
V1 and V2 are required to be positive values and limited to 10V, and V2 is slightly lower than V1. Resistors R1, R2 and capacitor C1 are required to use components with good temperature stability. A1 is HA2-2520, and A2 and A3 are LM101A.
- Dual video amplifier circuit
- Universal active filter circuit
- Two-stage video amplifier circuit
- Select amplifier circuit
- Variable gain amplifier circuit
- Single-phase full-wave rectifier capacitor filter circuit
- Precision instrument amplifier circuit
- Differential amplifier circuit with adjustable gain and common mode rejection ratio
- AC voltage measurement circuit with wide linear range
- Basic feedback amplifier circuit
- Working principle diagram of RS flip-flop
- Analysis and design of AC amplifier circuit composed of integrated operational amplifier
- Zener diode white noise generator circuit
- Two-stage resistor-capacitor coupling amplifier circuit
- IGBT working principle diagram
- Schematic diagram of multi-carrier frequency modulation
- Three types of wiring for isolation layer of isolation transformer
- 10MHz low-pass filter circuit diagram composed of OPA603
- Fifth-order Chebyshev multiple feedback low-pass filter
- DC error-free low-pass filter circuit
