Working principle diagram of RS flip-flop
Source: InternetPublisher:newrudeman Keywords: NAND gate analog circuit high level rs flip-flop Updated: 2020/08/20
Shown is a diagram showing the working principle of the RS flip-flop. When the switch is neither at the S end nor the R end, the output end of the flip-flop
is uncertain. When the switch is set to one side, it determines the output of the flip-flop. For example, when the switch is placed at the S terminal, the S terminal is low level (ground).
The R terminal is high level, the input of NAND gate ① is low level. The input of NAND gate ② is high level. In this way, the Q terminal output of the flip-flop is
High level, the output of Q terminal is low level.
If the input switch is placed at the R terminal, the flip-flop will reverse, the Q terminal becomes low level, and the Q terminal becomes high level.
all
It can be seen that the input terminals R and S can neither be high level nor low level at the same time. There are only two situations, among which
If one is high level and the other is low level, signals with opposite status will inevitably appear at both ends of flip-flop Q and Q.
![Working principle diagram of RS flip-flop](http://www.eeworld.com.cn/circuit/upload/0c1126cf9d455c96e5b88239846bf00f/c4a79408b85d1a3c6d85227a07ce4d1e.gif)
- What is a photocoupler and how to select and use one?
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- RC filter explained in detail
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- How to calculate the value of capacitors in parallel?
- Beautiful crown wreath made with LED
- Ceramic filter structure/working principle/characteristics/application
- How to build a triangle wave generator using an op amp and discrete components
- How to install the accelerometer
- Star finder battery indicator circuit
- Diode tester circuit
- BTL type amplifier circuit diagram and characteristics
- DC tube amplifier working in Class B
- Secondary circuit circuit schematic diagram and explanation
- Basic summary of MOS tube drive circuit
- Biased push-pull power amplifier circuit
- Bidirectional anti-shake circuit
- Anti-shake circuit using RS flip-flop
- NAND gate controlled AC switching circuit with isolation transformer
- 555RS trigger
