Finite bipolar control logic generation circuit
Source: InternetPublisher:红水杯 Keywords: control logic hall sensor Updated: 2021/04/04
The picture above shows a bus door status detection circuit . This circuit is mainly composed of three Hall sensors and is suitable for indicating the door status in various cars. Three Hall sensors are installed on the door frame of the bus door, and magnets are installed at appropriate positions on the door. When the door is open, the magnet is farther away from the Hall sensor so that its output terminal outputs a high level . If any one of the three Hall sensors detects that the door is not closed or locked, the NOR gate outputs low level and the red indicator light turns on; if all three sensors output high level, the NAND gate outputs high level and green The indicator light is on, showing the current status of the door in real time.
- The basic principles of power supply design. What are the key components of a power supply?
- Schematic diagram of car cigarette lighter to USB power port
- Practical and convenient fax machine power supply control circuit
- Energy-saving motorcycle rectifier regulator
- Step-down power supply for driving relays
- Basic circuit description of adjustable voltage regulator LM317
- Basic connection circuit of signal and power supply composed of ISOll3
- Low cost and high performance LED constant current power supply
- Charging control circuit made by solar energy
- LM317T voltage regulation adjustable circuit diagram explanation
- Laser power circuit
- Portable device charging power circuit design
- Voltage stabilization control circuit in power circuit
- Single phase thyristor slotless nickel plated power circuit
- Recording level power supply circuit
- Karaoke light controller circuit (1)
- Common power circuits and applications 08
- Telephone power circuit
- 5V, 7.5V, 48V power circuit
- ±5V, ±12V power circuit A
