Contact relay output control interface circuit
Source: InternetPublisher:狂妄火龙果 Keywords: Interface circuit contacts output control relay output Updated: 2021/02/01
When the switching output terminal PAO output is high level, it changes to low level through the inverting driver 7406, causing the light-emitting diode to emit light, thereby
turning on the photosensitive transistor and at the same time turning on the transistor VT, thus energizing the coil of the relay K , the relay contact is closed, turning on
the AC 220V power supply. On the contrary, when the switching output terminal PAO outputs low level, the relay contact is disconnected. In the figure, the resistor RL represents the load
, and the diode VD functions to protect the transistor VT. When relay K is closed, diode VI) is cut off, which does not affect the normal operation of the circuit
. When the relay is released, due to the existence of the inductance of the relay coil, electric energy is stored. At this time, the transistor VT has been cut off, so a
higher induced voltage will be generated at both ends of the coil. The polarity of this voltage is up and negative. Positive, the positive terminal is added to the collector of transistor VT. When the sum of the induced
voltage and Voc is greater than the collector reverse voltage of the transistor VT, the transistor VT will be broken down and damaged. After adding the diode VD
, the induced current generated by the relay coil flows through the diode VD, clamping the extreme voltage of the transistor VT collector, thus
protecting the transistor VT.
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the classifications of filters?
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Build a musical fountain using Arduino and sound sensor
- Summary of knowledge points of multiplexer
- LED lights that “drain” battery power
- LED Bicycle Lights
- Minimum system interface circuit based on AT89C52 microcontroller
- AD574 and PC bus interface circuit
- Interface circuit between AD574A and PC bus
- Interface circuit for automatic counting using electronic counter d
- Interface circuit c for automatic counting with electronic counter
- Interface circuit between CMOS and PMOS c
- Interface circuit between CMOS and ECL a
- Interface circuit between power supply coupler and PLC
- Interface circuit for photosensitive device and TTL matching
- Interface circuit between CMOS and transistor
