LED lights that “drain” battery power
Source: InternetPublisher:石榴姐 Keywords: LED Circuit Updated: 2024/10/31
This LED lamp uses only three transistors and only requires a voltage of 0.71V to start the LED to emit light. One No. 5 alkaline battery can allow the lamp to light continuously for 170 hours, greatly maximizing the battery utilization rate.
The power supply voltage of the LED lamp is set according to the voltage range of 0.9V to 1.7V of the No. 5 alkaline battery. Figure 1 shows the actual battery power supply situation. This circuit can work up to a power supply voltage of 0.71V.
The circuit is shown in Figure 2. The forward current of the LED changes with the power supply voltage. Transistors Tr1 and Tr2 form a current mirror circuit to stabilize the bias (DC operating point). During the off period of Tr3, the bases of Tr1 and Tr2 are slightly reverse biased, and no current flows through R1. As a result, the circuit can oscillate stably over a wide temperature range, battery voltage, and component error range. Figure 3 is the collector voltage waveform of Tr1.
The DC resistance of inductor L1 in Figure 2 is 4Ω. Its larger resistance can limit the current when Tr3 or LED is short-circuited.
- Analysis of the flow direction of transistor current
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Analysis of the basic principle of measuring resistance by bridge method
- What are the classifications of filters?
- What is a D flip-flop and how does it work?
- Analysis of three simple electronic dice circuits
- Important things to know about PCB routing and how to design the right routing for your PCB
- Tutorial on building a NOT gate using BJT transistors
- How to install the accelerometer
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- simple photometer
- Photoelectric conversion and voltage-to-current conversion circuit diagram
- Capacitor step-down LED drive circuit diagram using varistor
- Capacitor step-down LED drive circuit diagram using thyristor
- Energy-saving household small neon light circuit production
- Typical circuit diagram of LED indicator integrated circuit
- Novel solar LED light controller circuit diagram
- LED lighting circuit diagram in refrigerator
- MIC2298 driving LED circuit diagram
- MAX1913 driving white LED circuit diagram
