AC Voltage Multiplier (MC1594)
Source: InternetPublisher:公子李 Keywords: Multiplier Updated: 2024/09/05
As shown in the figure is an AC voltage multiplication circuit. This circuit is composed of MC1594 four-quadrant multiplier. The circuit is simple and the accuracy is slightly poor. In order to make the circuit work in the linear region, the value of the input resistors R1 and R2 depends on the input voltage. The value of R1 is equal to V1 multiplied by 6, and the value of R2 is V2 multiplied by 3. If V1=V2=3V, then R1=18kΩ, R2=9kΩ. In the case of different input voltages, R1=52kΩ, R2=30kΩ is generally taken, but this will reduce the accuracy and linearity. The relationship between output and input is:
Vo=V1V2/10
- Wireless temperature and humidity sensor (with USB interface)
- Battery charger current indicator
- Connecting It Up: High-Speed LVDS Comparators
- The Basics of Op Amp Loop Stability Analysis: Breaking the Loop
- The Basics of Op Amp Loop Stability Analysis: A Tale of Dual Loop Gains
- Preventing Output Polarity Reversal in High-Speed Amplifiers
- Diode and gate circuit schematic diagram and principle analysis
- How to understand operational amplifiers in a simple and easy way
- Judgment of series feedback and parallel feedback
- Analysis of the circuit for selecting the minimum/maximum voltage of four input voltages
- Triangular wave-square wave-sine wave generator circuit diagram using multiplier
- Quadrature oscillator circuit diagram using multipliers
- 4-quadrant 8-bit multiplier
- Multiplier circuit composed of multi-function converter 4302
- Square circuit composed of multiplier MPY600
- Square root circuit diagram composed of multiplier MPY600
- Divider circuit composed of multiplier MPY600
- Multiplier circuit diagram composed of multiplier MPY600
- Divider circuit diagram composed of multiplier MPY100
- Multiplier circuit composed of multiplication and division integrated circuits
京公网安备 11010802033920号
