Using 8255 to expand 64-channel input interface circuit
Source: InternetPublisher:Lemontree Keywords: interface circuit interface switch signal programming Updated: 2020/11/02
In a computer control system, when there are many switch signal circuits that need to be detected, a large number of input interfaces need to be expanded so that
all switch signals can be input to the computer. When the programmable chip 8255 is used to expand the input interface, each 8255 has 3 1/0 interfaces. All of them are initialized to the input working mode through
programming . Up to 24 switching signals can be input. Therefore, according to the number of input switching signals You
can calculate the number of 8255 chips required. Figure 27-29 shows the circuit using 8255 to expand the 64-channel input interface .
- Which one is better, NPN or PNP transistor?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- How to identify common mode interference? Methods to eliminate common mode interference
- How to install the accelerometer
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Experimental circuit based on 4040 binary adder counter
- Touch circuit design and analysis
- Star finder battery indicator circuit
- LED lights that “drain” battery power
- Temperature control interface circuit
- Alarm interface circuit
- Thyristor triggered interface circuit a
- Switching interface circuit in timing query mode
- Interface circuit between AD574A and PC bus
- Memory interface circuit example
- Intelligent control module and 0-5V signal interface
- Speech synthesis integrated circuit HM2081 and 8031 interface
- CMOS-Light Emitting Diode LED Interface
- Double contact switch signal input circuit
