Mechanical electric shock switch value conversion circuit b
Source: InternetPublisher:李商隐身 Keywords: switch conversion circuit contact Updated: 2020/06/21
It is a conversion circuit for mechanical contact switching. The switch conversion circuit with its own power supply in the control system is generally used in situations where the switch is installed close to
the computer control device. The power supply is DC 24V or less. Commonly used circuits have two forms: series and parallel . For parallel circuits
, when the contacts are closed The output % is high level, and Vo is low level when the contact is open. A series circuit is just the opposite. The external power supply switch value conversion
switch is suitable for situations where the switch is installed far away from the control device. When a conversion circuit in the form of a DC power supply is used , the two transistors are protective
components, and the power factor should be considered in the selection.
- Which one is better, NPN or PNP transistor?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- How does a series arrangement of Zener diodes affect the electrical behavior?
- In-depth analysis of energy losses in oscillation frequencies
- What are the parts of the fpga design process
- Transfer characteristics of BJT, how to apply Shockley equation?
- Analysis of three simple electronic dice circuits
- Tutorial on building a NOT gate using BJT transistors
- Experiment and production of NE555 time base integrated circuit
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Improved single-stage PFC conversion circuit diagram
- Celsius temperature conversion circuit diagram for thermometer
- Transformation circuit diagram
- Use 555 to form a DC step-down conversion circuit diagram
- 555 DC boost conversion circuit diagram
- DC/DC conversion circuit diagram without isolation
- Voltage doubling conversion circuit diagram 2
- Voltage doubling conversion circuit diagram 1
- MAX608 buck-boost conversion circuit diagram
- Differential input voltage-current conversion circuit 1
