Wearable wrist electronic blood pressure monitor sensing circuit design diagram
Source: InternetPublisher:ghaytweyhtoo Keywords: Electronic blood pressure monitor circuit design wearable sensing circuit Updated: 2021/12/06
Circuit principle: This circuit uses the BP01 pressure sensor and the operational amplifier MAX4472. The BP01 pressure sensor is specially designed for detecting blood pressure and is mainly used in portable electronic blood pressure monitors . It uses a precision thick-film ceramic chip and nylon plastic package, which has the characteristics of high linearity, low noise and small external stress; it adopts internal calibration and temperature compensation methods to improve measurement accuracy, stability and repeatability. Within the full range, The accuracy is ±1% and the zero point offset is not greater than ±300μV. MAX4472 is a low-power amplifier chip from MAXIM that integrates four operational amplifiers. In this system, the internally integrated operational amplifier A is connected to a constant current source to provide a constant current for the pressure sensor. The operational amplifier B, operational amplifier C, and operational amplifier D form a differential input and single-ended output amplifier circuit, and are directly input to ADC0 to monitor the DC component of blood pressure.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- How about the boost converter TPS61299?
- A very convenient small power supply circuit to share
- Fabrication of multi-cell lithium battery charging circuit
- Practical and convenient fax machine power supply control circuit
- Energy-saving motorcycle rectifier regulator
- Transformerless AC-DC constant current LED driver circuit
- A simple positive and negative power supply circuit
- Electric bicycle battery charger circuit
- Mc34063 MP3 Switching Charger
- Importance of Voltage Supervisors and Output Topology Selection
- 3v to 5v circuit diagram
- Power circuit with smoothing filter capacitor
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Head amplifier dedicated power supply circuit
- Power circuit for home appliance repair
- Common power circuits and applications 09
- Inverter power circuit made with BJ50A
- Sensing circuit reverse voltage protection circuit
