Varactor diode frequency modulation oscillation circuit
Source: InternetPublisher:小胖友 Keywords: Diode oscillator circuit Updated: 2024/08/30
①The figure below shows a capacitor three-point oscillation circuit, which achieves frequency modulation through the capacitance change of the varactor diode.
②The special point of this circuit is that two varactor diodes are used and connected to the oscillation circuit in the same polarity. Since two diodes replace one diode in the circuit, the high-frequency voltage across each varactor diode is reduced. This reduces the influence of the high-frequency voltage on the total capacitance of the varactor diode.
③ The high-frequency choke is short-circuited to the DC and modulation signals, but open-circuited to the carrier frequency. Therefore, the reverse voltage applied to the two varactor diodes is the same.
- Two common RC oscillator circuits
- LM324 op amp makes a step wave generator
- A relatively complete ultrasonic generator circuit
- AD585 applied to A/D conversion system circuit
- Complementary symmetric astable multivibrator circuit diagram
- Cleverly designed voice-activated electronic doorbell
- Precision gate oscillator circuit
- RC bridge oscillator and its equivalent circuit
- Five frequency standard frequency standard generator
- Voltage to frequency conversion circuit
- Can you use the new high-voltage thyristors and diodes?
- Schottky and Silicon Carbide Diode Analysis
- Quasi-circuit--Miscellaneous talk on rectification (2)
- Intrinsically protected safety op amp
- Acousto-optic digital level detector circuit diagram
- Automobile electronic fuel saver circuit diagram
- Diode IN148 temperature measurement circuit
- Mosquito killer lamp circuit
- Mixing circuit
- buffer amplifier
