Four-speed touch dimming circuit designed with MC14017
Source: InternetPublisher:Lemontree Keywords: Dimming circuit Updated: 2024/09/03
The circuit is shown in the figure below. After the power passes through the light bulb, it is rectified by the BR1 bridge, and then limited by the resistor R1, filtered by the capacitor C1, and stabilized by the voltage regulator D1 to provide a 6V DC power supply to the integrated circuit MC14017.
R2, C2 and push button switch SW1 form a clock pulse trigger circuit. Each time SW1 is pressed, a pulse is input to U1's (14) pin, and U1's (3), (2), (4) and (7) pins output high levels. Due to the different values of R3~R6, the Vb voltage of transistor Q1 varies between 0.28V, 0.52V, 0.62V and 0.63V, and the conduction degree of the thyristor SCR is also different. Therefore, the light bulb changes cyclically between full brightness → brighter → dark → darkest → full brightness, achieving the purpose of four-speed dimming.
- Controlling LEDs with Node-RED in Raspberry Pi
- Introduction to the internal structure of the Delta winding motor
- How to set up a cheap beam break sensor control distance scene using a reflector
- Design and analysis of wire control circuit
- Design and analysis of a four-bit remote control component capable of remote reset
- Design and analysis of voice control circuit
- Simple three-phase motor phase loss protection circuit
- Magnetic door and window anti-theft alarm
- Ultra-short wave item left behind reminder alarm
- Water supply reminder after water outage
- Electric plow control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Photocell amplification control circuit
- Boiler control circuit
- AM radio automatic search and trigger circuit
- sound control circuit
- Relay control circuitb
- Photoelectric detection output control circuit
- audio signal control circuit
- Apply LOGO! Electric gate control circuit b
