audio signal encoder circuit
Source: InternetPublisher:念慈菴 Keywords: encoder audio signal signal encoding Updated: 2021/04/09
After the MP3/MP4 machine receives the microphone signal or line input signal, it should be sent to the audio signal encoder for encoding. As
shown in the figure, the circuit diagram using the UIL WM8731 integrated encoder is used. The audio signal from the microphone is amplified by the amplifier and sent to the
@ pin of the audio signal encoder Ull. The two-channel audio signal from the audio switching circuit is sent to the @ and @ pins of Ull. foot. UIL first performs switching processing on the input audio signal
and then performs A/D conversion and digital encoding, converts the analog audio signal into a digital audio signal, and stores it in the memory under the control of the CPU
to complete the storage of the audio signal .
- DIY a hollow clock
- radio circuit
- The structure of Hisense KFR-25GW-06BP inverter air conditioner outdoor unit microprocessor control circuit
- Lihe ESA-25 temperature-adjustable electronic crock circuit diagram
- SH-2 computerized rice cooker circuit diagram
- Broadband high frequency amplifier
- Color TV adds AV output socket
- Yangzi brand BCD-212, BCD-230 refrigerator circuit
- small hearing aid
- TV automatic frequency control circuit
- Audio signal encoding circuit integrated into the CPU
- Encoder circuit composed of 148-LS148
- Equivalent circuit with bass attenuation
- Encoder, decoder circuit diagram
- Inverting Schmitt encoder
- CMOS oscillating encoder
- 555 time base encoder
- Priority interrupt encoder circuit
- 9-channel pulse encoder
- Clever use of LB1405 as audio signal amplifier circuit diagram
