Broadband high frequency amplifier
Source: InternetPublisher:兰博 Keywords: frequency band high frequency amplifier BSP high frequency signal Updated: 2021/12/02
Shown is a wide-band high-frequency amplifier . This circuit uses a common-emitter amplification circuit with resistance-capacitance coupling, which can be used to amplify
high-frequency signals .
The high-frequency signal is supplied to the Jl terminal (input impedance 50 n), and is added to the base of the amplifier VTI via the coupling capacitor cl. After amplification, it is coupled
to the base of VT2 by c5, and the amplified signal is output from the collector. Adjusting the capacitors marked with "※" can make the frequency characteristic within the band reach ±1 dB.
The capacitors marked with "※" are high-frequency compensation capacitors.
- Using CD4017 to form an analog pendulum circuit
- CD4011 application circuit - inductive wireless headphone circuit
- Zhongyi brand BCD-215 refrigerator circuit
- Full CMOS receiver
- Thundercloud distance detector circuit
- Universal inverter external knob forward control
- Electric heating water dispenser circuit
- Simple stepless speed fan circuit
- LG Industrial iV5 inverter typical application circuit (2)
- Amplifier DIR1703+PCM1738 DAC PCB circuit diagram
- Voice controlled flash LED light circuit diagram
- strain sensor
- Pulse therapy circuit
- Rice mill circuit
- Poultry warming temperature control circuit
- Mixer built with analog multipliers
- Double detuned loop frequency discriminator circuit
- Frequency modulator composed of NE566
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
