1 hour timer using LM122
Source: InternetPublisher:偷熊计划 Keywords: Timer Updated: 2024/09/02
As shown in the figure, this is a 1-hour timing circuit using LM122. The switching of the start, reset and midway stop of this circuit are all operated by switches. In the figure, S1 is the start timing. When the timer is started, pressing this switch again will not have any effect. S2 is the "off" switch located in the center. The timer can complete: charge-open circuit-discharge through the switch conversion. Since the charging is stopped midway, even if the timer setting time has not been reached, the charging position will return to the working state of the timer output circuit. When C is discharged and the voltage at the R/C terminal is zero, the discharge position waits for the start signal of S1. Even if the position is restored, the working state of the timer output circuit will not change. Therefore, when the timer is reset during operation, the state of the output circuit remains the same. At this moment, C starts charging again and changes to the starting point of the timer working time.
- Design and selection of electric control valve system drive
- How to build a simple tachometer using an infrared reflectance sensor
- How can we make the robot move precisely on a predefined path?
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Working principle of one Xipu STR soft starter controlling two motors
- Design and analysis of a four-bit remote control component capable of remote reset
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Infrared detection alarm
- Water supply reminder after water outage
- Password type motorcycle anti-theft device
- Micro remote control receiving and control circuit
- Electronic rhythm control circuit
- Paper tension control circuit
- via multifunctional alarm and timer (555) circuit
- Timer circuit that displays time using light dots
- Precision countdown timer
- Automatic power off timer
- A novel timer
- Micropower timer
- 9V charger with digital circuit timer
